Any ideas as to why I can Reply to some posts but not others?
Today, I can reply in the Open Roads Forum but not the MicroStation forum. When I select one of the Reply hyperlinks, nothing happens.
Upon further testing, it may be related to a single thread: http://communities.bentley.com/products/microstation/f/273/t/120672
I cannot use the Reply hyperlink on this thread - on multiple PC's and browsers.
  • Hello caddcop,
    I am able to reproduce this problem in the example thread you provided. Even as a Site Administrator, I cannot use the reply button or any of the other options in that thread.
    This is not something I have seen before and I am not sure what is causing this. We'll investigate this further and will let you know if we find a resolution. If you encounter any other threads with this problem, please let us know.
    Jesse Dringoli
    Bentley Systems, Inc.
  • Hi caddcop - you should now be able to reply to that thread.
    The problem appears to have been due to the Preview items being included in a quote in the most recent post. To resolve this, the quoted preview items have been removed from the last reply. The root cause will be investigated so it doesn't happen again.
    Thanks for reporting this.
    Jesse Dringoli
