Mmmm... MicroStation?
It is unclear what your inquiry relates to. Could you provide more context regarding that? TIA
actually i want to read the dwg and dgn formats in my project which is in C#.
now i want a library through which i can read both.
can u suggest me a single library that can be used for both instead i buy for each.
or do u have any idea of the formats of both? i dint get any format so going for a library.
can you help me in that?
coz i got no idea of that and can you plz elaborate how microstation can help. i dint get your words actually.
plz describe,
priyanka131: can you help me in that? coz i got no idea of that and can you plz elaborate how microstation can help. i dint get your words actually. plz describe,
You have to use Microstation and you can not create a standalone application with c using the libs all around the Microstation installationOr you have a lot workFrank
Frank
