As attached, inside there is a file named "0001.000".
I tried to open it by 7zip, UltraISO, Winzip, ARJ.... but failed. And then I opened it by notepad and saw "Creator: MicroStation 7.2.4.14"
I guess it was compressed by Microstation.
The another one, 501.000, do not include Creator, but I'm not sure if it is bentley by product. (such as InterPlot?)
[PS: There's no other file, such as 0001.001, 0001.002...]
they are Encapsulated Post Script files... plot files that are supposed to be sent to a printer.
If you rename them to <file name>.eps and then go to this web page, they will convert them to an image file that you will be able to see.
I've just done it now and it seems to work. I've attached the result of the 0001.000 file conversion.
http://www.zamzar.com/
Yes.... the first one, "0001.000" can be converted. But the another one, "501.000" likely not the Post Script files.
Solved, the another one is to use somethings like PCL/HPGL2 viewer. Thanks guy.
