Maybe I am just a little rusty at Corridor Modeling, but I can't seem to get my Active Surface to show up in Roadway Designer. So any elements that tie to the active surface are not drawing in the section view. I can't seem to remember ever running into this before. I do have SS2 and SS3 Suites installed on this computer. Just thought I would mention that since most of my latest issues have been due to this.
Corridor Modeling Window:
DTM files path is pointing at my roadway folder, which I believe is correct
I have added and imported my GDTMRD01.tin file
All Geometry and Plan Graphics are imported and are working in Roadway Designer
Template Design:
All tie downs are targeting active surface and work when I do a Test
Roadway Designer:
My Corridor, Template Drops, Point Controls, and Parametric Constraints are all working
Only thing not working is the active surface, which I have GDTMRD01 selected in the drop down.
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
YouTube Page for ORD: https://tinyurl.com/BillingsCADD
