Template modification
Once you modified your template in your design file how do you save  back to your library?
  • In the Create Template dialog, use tools> template library organizer.  There on the right side it allows you to pick a template from the active file.
    Vern Danforth, P.E.
    Engineering CADD Systems
    Florida Department of Transportation
    Phone no: (850) 414-4897
    Toll Free no: (866) 374-3368 extension 4897
    How am I doing?  Please contact my supervisor with any feedback,
    Vern
  • Navigate to the Task Navigation > Civil Tools > Corridor Modeling > Create Template tool.
    On the Create Template Dialog, navigate to Tools > Template Library Organizer.
    On the Template Library Organizer dialog, find the second Available In pane to the right of the dialog and double click on the Active Design File Corridors folder. These Templates are the Templates in your active design file.
    Select the Templates and drag and drop them in the Available In pane to the left side of the dialog.
