In a FDOT modified template the pgl right is plotting correctly but the PGL left has a constant error and when it get to the super elevation section it gets worst.
Those anybody know why the cause PSL_1.LT_PVT_EOP_IN is not fallowing the PGL_LT.PGL_LT
Unknown said:Your image didn't post, however, usually when you establish a Point Control linking a point to an alignment/profile and it doesn't conform it's due to the following: The wrong point was selected to control. The correct point is selected, but configured to the incorrect Horizontal/Vertical Alignment. There's already an established control for the point that can not be overridden, usually due to station ranges configured on other point controls. Point control is configured incorrectly due to needing both horizontal and vertical control and only 1 or the other is configured. There could be more issues to note. Please send me your data set for review. I can probably locate the issue and let you know how to correct the issue. Thank you,
I sent you the file via FDOT e-mail.
Vern
