I'm working in SS4 and created a proposed model and proposed cross sections. There is a lot of detail modeling to I'm trying the alternative labeling method. I have added all the feature names to the proposed cross sections. I then opened the Cross section VBA and keep getting the error, "No Cross Section Cell Stored in the Design file." Does anyone know how to fix this?
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
YouTube Page for ORD: https://tinyurl.com/BillingsCADD
Try the following:
Close MicroStation.
Run Clear Crash.
Delete the GEOPAK resource files ( C:\FDOTSS4\Temp\GPKRSC)
Navigate to the C:\Users\***Your Username***\AppData\Local\CadManage\ folder and delete it.
Navigate to the C:\Users\***Your Username***\AppData\Local\Bentley\MicroStation\8.11\ folder and delete it.
Note: If you are running PowerGEOPAK this will be under the PowerGEOPAK directory.
Navigate to the C:\Users\***Your Username***\AppData\Local\Temp\ and delete everything you can.
Note: You won’t be able to delete everything. Once you get the Try Again/Skip dialog toggle on the do this for the remaining files/conflicts check box and chose Skip.
Navigate to the C:\Users\***Your Username***\AppData\Roaming\Bentley\EngineeringLibraries\.
Delete the EngineeringLibraries.sqlite and EngineeringLibraries.sqlite01.bak files.
Delete the *.upf file. C:\FDOTSS4\Workspace\prefs\FDOTSS4.upf
Restart MicroStation.
Let me know if this helps…
