2. Go back to the 2D line and use the Open Profile Model and to see the profile
3. On the profile properties, right click on element to open, name the profile
4. If you then need(?) to export these to the GPK for some reason, use the General Geometry – Export to native.
a. Select the 2D plan element
b. Select the gpk file for exporting
