Corridor Objects crashing Microstation
Microstation is crashing every time I try to open Corridor Objects. I have cleared crashes and even delete the temp files from my C drive. Any suggestions on how to fix this problem? I am using: Microstation V8i (SELECTseries 3) Version 08.11.09.714 Geopak V8i (SELECTseries 4) Version 08.11.09.845
  • Try the following:
    1. Close MicroStation.
    2. Run Clear Crash.
    3. Delete the GEOPAK resource files ( C:\FDOTSS4\Temp\GPKRSC)
    4. Navigate to the C:\Users\***Your Username***\AppData\Local\CadManage\ folder and delete it.
    5. Navigate to the C:\Users\***Your Username***\AppData\Local\Bentley\MicroStation\8.11\ folder and delete it.
    Note: If you are running PowerGEOPAK this will be under the PowerGEOPAK directory.
    6. Navigate to the C:\Users\***Your Username***\AppData\Local\Temp\ and delete everything you can.
    Note: You won’t be able to delete everything. Once you get the Try Again/Skip dialog toggle on the do this for the remaining files/conflicts check box and chose Skip.
    7. Navigate to the C:\Users\***Your Username***\AppData\Roaming\Bentley\EngineeringLibraries\.
    8. Delete the EngineeringLibraries.sqlite and EngineeringLibraries.sqlite01.bak files.
    9. Delete the *.upf file. C:\FDOTSS4\Workspace\prefs\FDOTSS4.upf
    10. Restart MicroStation.
