Apply superelevation to alignment different from the corridor
I have a corridor which is created along the centerline of the road. I also have 4 PGL chains along 4 different EOPs that are used as point controls on the template. I am attempting to apply superelevation to a pavement section and I have the superelevation section created off the chain of a PGL. When I try to apply the superelevation off the PGL chain onto the corridor connected to the centerline chain It is not being reflected in the cross section view. I am able to select the correct points from the template to apply the superelevation too and I have all the flags checked on in the template.
In short am I able to apply superelevation that is based off one chain and apply it to a corridor on a different chain?
I am working in GEOPAK V8i SS4 Version 08.11.09.845
