Sidewalk Only Template
I am attempting to create a template for my sidewalk project. This is a sidewalk only job, with a small portion of pavement removal at the beginning. I believe I have most of the template correct; I seem to be having issue with having the unpaved shoulder in front of the sidewalk connect to the existing EOP.
I am new at Corridor Modeler, so I am not quite sure how to control these end conditions.
Here is an example of the begin project.
The rest of the project is very similar except for the pavement removal. All other sections will be tieing into existing eop.
  • Import the Existing EOP from the Topo file as a New Chain for Corridor Modeling and have the point where the Utility Strip/Unpaved Shoulder will connect/target the Existing EOP and modify the template point Style Constraint to look for the Pavement - Existing style and specifiy a Horizontal distance to 'look' for the Existing EOP.  Keep in mind positive nubmers are specified to look to the right of the point (ie. 1, 2, 3 , 4 , 5 etc.) and negative numbers are specified to look to the left of the point (ie. -1, -2, -3 , -4 , -5 etc.).
