I am trying to make an end condition that targets my top of berm elevation on a pond. The pond is going to be constructed adjacent to a roadway that is in fill, so the fill slope will be coming down to meet the top of berm elevation of 17.90. I grabbed the 1:2 fill component and adjusted the target type to Elevation. Now I cannot figure out where to actually set what elevation it is targeting. I want to make this target 17.90 so that I can create my proposed surface and let my drainage sub know about where to put his top of bank.
End Condition Component Properties
Vertical Offset
specifies a vertical offset from the target. Applies only if the target is a vertical target or has a vertical aspect. For an elevation target, specify the elevation here.
Vern
Answer Verified By: Vern Danforth
Thanks Vern
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
YouTube Page for ORD: https://tinyurl.com/BillingsCADD
