Slope Tolerances
I came across an issue with CM drawing side slopes at a rounded up value ( 1:6 = 17% instead of 16.67%)
This was causing differing offsets between cross sections cut with FDOT Criteria and CM.
Vern directed me to the below setting as the fix. Now my tie-down offsets match.
Thanks Vern.
