I have Microstation 08.11.09.608 installed with Descartes 08.11.09.601.
When I use the key-in "mdl load dcartes", descartes loads as expected.
When I use the key-in "mdl unload dcartes", nothing seems to happen.
If I use key-in "mdl unload descartes", it says "descartes unloaded", however, it still appears to be loaded.
In earlier versions of Microstation, this didn't occur.
Can anyone confirm whether this is a bug, or has something changed that I'm not aware of?
I can easily just have Descartes load at startup, and leave it loaded, but we rarely use descartes.
Hi Peter, This was changed for 2014 releases, it is no longer possible to unload "dcartes". There are a couple of reasons for this change, one of them being licensing. Thanks, Simon
