Reference: {SrvReqNo:[7000031663]}eB version 14.6.2Kofax Capture 8
A user is getting the following errors, which our internal QA system cannot replicate.
Has anyone seen this in the field?
"Release Error: Script #1 (eB Capture 8.0 Release) [0 eB API Error: There is no Repository in the relevant Repository Group that is 'Online', 'Write Enabled' and 'Served by a Storage Module'. If no Repository Group was specified then please ensure..."
"Release Error: Script #1 (eB Capture 8.0 Release) [0 eB API Error: Adding this record was unsuccessful because it makes a reference to data (either List Values or Object Instances) that does not exist.
I checked the SR, and it looks like the error is only with 200 or more files? Can you check the Search results limit for the eB user that runs the release script (usually ADMIN)?
Address: Bentley | 10052 Mesa Ridge Court Suite100 | San Diego | CA | 92121 | USA
