Getting Started Common Acronyms FAQ Forum Help Forum Tips FTP Site Helpful GuidelinesInserting and Attaching images, videos, or files to postsProduct Community Directory SELECTsupport
And as a architect. The problem then becomes the lack of change. When the hollow core changes shape, stretches, etc. Sometimes this can be easy and sometimes not.
I did it by creating a curb round the shape of the slab. then made a singular slab and "Cut stuff out. I can stretch the length but just not the width.
We use a custom rectangular section to create a structural member. Attach family/part, make it longer then necessary, cut the voids and keyways with the cut solid tool. Now you can use structural manipulate and modify tools as required.
<Andreas Zieritz> wrote in message news:110881@communities.bentley.com... There are not more than 10 different section types, so it would be possible to do it. The question is, how? As stated before, the best solution would be to have them defined as a structural section. But I am not sure if Bentley wants to do that. So what's the next best solution? Parametric cells? http://communities.bentley.com/Products/Building/Building_Analysis___Design/f/5917/t/48688.aspx#110881
<Andreas Zieritz> wrote in message news:110726@communities.bentley.com... The problem are cut sections. They should be different according to if you cut normal or parallel to the span direction. As a structural engineer this is important to me. http://communities.bentley.com/Products/Building/Building_Analysis___Design/f/5917/t/48688.aspx#110726
Now mine is not as fancy as you show but I do have a general way to create hollow core slabs that work for my sections.
I create a slab without patterning. And include a linestyle with Circles.
One thing I'm really starting to miss is the possibility to use hollow core slabs in drawings. My preferred method would be to have them implemented as sections in a structural database (xml file).
But I'm open to alternative solutions, like parametric cells.
Any ideas?
