Hi
I am currently using BA 08.11.07.80 and am looking to upgrade to the latest version v08.11.07.87. I have a query regarding my existing dataset. I have created new components that have been added as company parts. Is there a way that these can be transferred into the new version or do they need to be recreated once the new installtion is completed. It appears that the old version of BA needs to be uminstalled prior to installing the new version. Operating system is Windows 7.
Kind regards
Mo
Mo:
This depends on how your company dataset is configured (network vs. local). It sounds like you have added your new components to the installed workspace. If this is the case, i would recommend that you make a copy of the current dataset, uninstall BA 08.11.07.80, install BA 08.11.07.87, and then sync the copy of your customized dataset with the freshly installed. There will not be any compatibility issues with the content that you created in the .80 version of Bentley Architecture.
HTH,
Travis
