That is the question.
I'm using Bentley Architecture V8i select series 2. I create a dynamic view (extraction from the 3D model) the line weights and hatches look okay, I live nest reference to a sheet but then when I print to PDF it automatically rasterises the drawing and I end up with very thin pixelated linework. Not good. Can anyone help?
Cheers
Oliver
If you are using a rendered view then the printer driver will automatically want to rasterize your print.
In DV's you are probably using "hidden line" which is a rendered view, hence the rasterization.
You may want to check the resolution of your output when using the rasterize funtion by looking it up in your settings (edit printer driver>Advanced) ours is set to 600.600 (600X600 dots per inch) which seems to be acceptable for printing but looks washed out on screen.
You MUST rasterrize or things will disappear. Damon is right, play with your resulition in your printer setup.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
