I see a problem with the stair. The drawing of the stairs disappears. See video.
Why this happens?.
AECOsim 08.11.09.225 Dataset_US
I can't seem to reproduce that... All I see when raising the cut plane above the stairs is that the break line symbol disappears.
Hi Steve, this is the problem.
If the section does not cut the stair, I do not see the stair . I only see the numbers of steps.
The representation should be as indicated in the PDF.
I tried it on another computer and windows xp and the problem is the same.
You do not have the same result that the video?
Hi Joaquin, no I am not seeing the same results. See the attached AVI.
Hello Steve, thanks for posting your video. Now I see the problem better.
I installed AECOsim and pattern on the walls section disappeared when did zoom. (Video stair1). The first question: why lines disappear when zooming?
I tried every Nvidia driver to resolve the problem. I did not find a good result. Only resolved with compatibility AECOsim =Windows XP. Now the section pattern is correct and not disappear when zooming , but this causes the problem that the stairs are not see in the plan.
In the video stair2, you can see that appears the stair in the plan, but is blocked and therefore does not appear, but what can it be?
This problem does not occur with BA 08.11.07.87, only occurs AECOsim (on the same computer with Windows 7 64).
The big problem is: why some lines desaparecen con AECOsim?. Knowing this would solve all problems.
Thank you for your help.
Video stair1 AECOsim not compatibilty with Windows xp (default install)
Video stair2 AECOsim compatibility with Windows xp
Hi Joaquin, what is the "compatibility AECOsim =Windows XP" that you're referring to?
FWIW, I'm running an NVidea Quadro 1000M and haven't noticed any issues quite like this one. If I understand correctly, using one setting results in the stair geometry missing when in the forward view, while the other setting results in intermittent hatch display on the cut plane?
