AECOsim 08.11.09.376
I need to create a manufacturer catalog for Flex Pipe. Actually I've already created catalogs for Pipes, Elbows, Reducers, Tees, but always based on catalogs that comes with the AECOsim, copying the MDB and XML, and editting(using the Generic catalog).
I tryed to create in the XML and MDB the records for itens that catalogs do not cover(couplings, flexpipes...), with the corrects xPaths, but it do not work!
Adolfo Ribeiro
I suppose that there is no way to create a manufacturer catalog for Flex Pipe.
Does your Flex Pipe database table and XML file contain only properties applicable to Flex Pipe? I can't say I've ever tried this before with this component type, but it seems (at least on the surface) that it would work in a similar fashion to other types.
Hi Steve,
I did one XML and one MDB only with the Flex Pipe settings, and nothing...
I already tried to include the Coupling in my actuals catalogs but also with no success.
There must be a way to create catalogs for the tools that are delivered with no catalogs.
Adolfo, please log this as a new SR with our support team. We may need a Change Request, or possibly additional assistance from development to address this one.
