Getting Started Common Acronyms FAQ Forum Help Forum Tips FTP Site Helpful GuidelinesInserting and Attaching images, videos, or files to postsProduct Community Directory SELECTsupport
Bnetley Facilities Forum Users,
Is there an automatic way to use Bar Codes to populate the barcode column in the Bentley Facilities database? Can a bar code reader be used which will automatically enter data into the barcode column in the Bentley Facilities database? What about RFIDs?
Thank you,
Michael
