Getting Started Common Acronyms FAQ Forum Help Forum Tips FTP Site Helpful GuidelinesInserting and Attaching images, videos, or files to postsProduct Community Directory SELECTsupport
Cesar: Is the interoperability options applicable to my version? I am using a Microstation V08.01.02.15 (1990-2003) version (not a Bentley Map)
KeithRaymond: Bentley Map's Interoperability features ...
You seem to be confused. You are reading a thread in the Bentley Map forum. Bentley Map is a GIS tool. However, you are using Microstation V08 version, not Bentley Map. MicroStation is a 3D drafting tool, not a GIS tool.
Clearly, not all features available in Bentley Map are available in other products. Those other products include MicroStation. So, no, Bentley Map interoperability options are not available in MicroStation.
Since you are not using Bentley Map there is little point in asking questions in this Forum. Instead, post questions about MicroStation V8.01 to the most appropriate Forum.
Cesar: I am using a Microstation V08.01.02.15 (1990-2003) version (not a Bentley Map)
Then post to the relevant newsgroup.
Hi there, I am using a Microstation V08.01.02.15 (1990-2003) version (not a Bentley Map), do you know how to import or plot a CSV database to the file, like when i want to plot multiple points using my version?
Cesar Calingasan
Hi, I am trying to import some ODBC access data that is in Britsh National Grid coordinate system but I can't seem to get the syntax correct in the vrt file. Does anyone know what the correct syntax is?
<LayerSRS>OSGB</LayerSRS> does not work
<LayerSRS>OSGB1936</LayerSRS> does not work
<LayerSRS>OSGB:1936</LayerSRS> does not work
<LayerSRS>BritishNationalGrid</LayerSRS> does not work
