GWP idpr conversion wont finish
Hi.
we changed our server and afther the change idpr conversion does not finish. After several tries i tried also whistler demo file and the result is the same - no errors, no info what so ever. On the old server all works fine. New server is:
Win. Server 2012 R2
intel Xeon CPU E52630 v2 2,6Ghz
4,0 GB RAM
64bit operating system
Administrator program has all the read write rights on the server machine!
Log info is:
Created : 4.06.2014 9:05:04
Executing command: C:\Bentley\GeoWebPublisher\iDprCnv.exe -input="c:\bentley\geowebpublisher\engine\workspace\projects\examples\geospatial\whistler\dgn\mosaic.dgn"|"c:\bentley\geowebpublisher\engine\workspace\projects\examples\geospatial\whistler\dgn\parcelsxm.dgn" -seed="C:\Bentley\GeoWebPublisher\Examples\Data\Seed.dgn" -symbologymode=PIXEL -type=DGN -resolutionFactor=1 -highPrecision=1 -output="C:\Bentley\GeoWebPublisher\iDpr/24a489cb-e876-4a7c-8a8a-9b4fa2546db2.idpr" -trace
Trace: Parameters list
Trace: -f=C:\Windows\TEMP\tmp22AE.tmp
Trace: Validating arguments...
Trace: Arguments have been validated successfully.
Trace: MS Process launched.
Trace: Current working directory 'C:\Windows\system32'.
Trace: Custom callback idprCnv_setGetDBKeyFromElmCallback published
Trace: Custom callback idprCnv_setSolveTooltipFromElmCallback published
Trace: Custom callback idprCnv_displayMessageFromCustom published
Processing...
Trace: Master file copy opened 'C:\Windows\TEMP\Bentley\GWPMSEngine\8.11\0nIy1_35wsH2QU7D6rO3jA\Seed_2304_1.dgn'.
Step 1 of 1...
Trace: Input file attached 'c:\bentley\geowebpublisher\engine\workspace\projects\examples\geospatial\whistler\dgn\Mosaic.dgn'.
Trace: Input file attached 'c:\bentley\geowebpublisher\engine\workspace\projects\examples\geospatial\whistler\dgn\parcelsXM.dgn'.
