gINT V8i exporting to Microstation
Geotechnical
This is where you can find and contribute to discussions, ideas, and other information about Bentley Geotechnical products.
  • rated by 0 members
  • This post has 1 Reply |
  • 2 Followers
  • This is data specific, you'll need to send the library, project and output specification to Bentley Technical support so that they can attempt to reproduce the problem and check what is configured on fence report.
    To make a support ticket, go to this page selectservices.bentley.com/en-US, and click on Service Ticket, login or register, then follow your nose.
  • Good afternoon,
    I have a question concerning gINT V8i and exporting to Microstation...
    I have a custom sheet setup for displaying Fences, I created it by adjusting the size like I wanted it, copying items from other sheets.
    Everything works perfect, using DXF Export and also Preview.
    When I export the sheet to Microstation the Vertical Scale along the left side of my Fences is not showing up (getting exported).
    I am using...
    The same fonts on my items for the fence.
    The gINT seed file : \Bentley\gINT\seed\seed2d_us.dgn
    gINT V8i
    Microstation V8i
    and all my levels are "on"
    Thanks!
    Curtis
Page 1 of 1 (2 items)
