There are multiplle pumps and pressur mains from the wet well. How to get volume passing through single pressure main?
Cant see anything in graph options!! - would appreciate help in this regard - thanks
SewerGems v -8i
Hello Aruna,
You can create the user data extension if you don’t have any field in the results which you are looking for , like volume in your case.
Here is the support solution which explains how to create formula based user data extension.
communities.bentley.com/.../5203.creating-formula-based-user-data-extensions.aspx
Hope that helps.
Sushma Choure
Technical Support Group
Bentley Technical Suppport
If you're using the GVF Convex solver (set in the calculation options), you can right click on the element of interest and choose "Totalizing Flow Meter". This tool allows you to calculate the volume through that element over a specified time period.
If you're using the Implicit or Explicit Dynamic solver, you can use the Hydraulic Reviewer, located under the Tools menu. This will show the mass balance of volume for various elements. So, you could look at the total volume in for the manhole downstream of the pipe in question.
Answer Verified By: Aruna BM
