Dear All,
I'm experiencing some problem with the text on the Sewer Cad Model. I create model using AutoCAD, but then when I finish the model, I go to the SewerCad to set some settings that I need. But when the file open-up, its quite hard to zoom-in. When I zoom-in to a particular node, its going smaller, but when I zoom-out its going bigger? What might be the problem? How can I troubleshoot this?
Please help. Thanks in Advance.
June
This is likely due to the setting the Drawing Style in your model. The following support solution should be able to help:
communities.bentley.com/.../16559.how-do-i-change-the-drawing-style-gis-o-solution-500000053801.aspx
Basically, you should try setting the Drawing Style to another setting, which will hopefully make the appearance of the elements when you zoom in and out better.
Scott
Answer Verified By: june_0809@yahoo.com
Thank you very much Scott. It works!
