Afternoon
Someone Please help on how to "define downstream pipe" on watercad V81, for the direction of the pump to change and be in the same direction as water flow. I have been searching the Internet for solutions for one and half day now and so far I haven't beenable to find any solution.
Kind Regards
Nhonho
If I understand your question correctly, all you need to do is double click the pipe and pick Node Reversal and hit <Reverse Start/Stop>.. If it is the pump that is backward, double click the pump and pick the correct "Downstream Pipe".
You can right-click on the pump and select Reverse from the options. If you look at the properties of the pump by double-clicking on the pump. The option to select the downstream pump is in the "General" data part of the properties.
Terry FosterTechnical SupportHydraulics and Hydrology product lineBentley Systems, Inc.
Thank you for assistance, this answer really helped me solve my problem.
