What is the best way to determine how to zone a network? My system has two water tanks that feed most of the municipality but they also have a pump house that draws water from another municipality to pressurize the lines and serve another portion of the municipality.
There is a similar forum post which you can have a look at. You will find the answer in last comment of the post.
communities.bentley.com/.../273830.aspx
More information about pressure zones you can find in the help documentation under the topic “Using the Pressure Zone Manager”.
Sushma Choure
Bentley Technical Suppport
For general modeling advice, I would recommend taking a look at our Advanced Water Distribution Modeling and Management book:
pages.info.bentley.com/books
Here are some chapters in particular:
Chapter 8.5 - Establishing Pressure Zones
Chapter 10.4 - Adjusting Pressure Zone Boundaries
