Hello
1- What is difference between ‘Save’ and ‘Save to Seed...’? There is no mention about the difference in help document.
2- Does ALL properties of an element export When a project is saved as a ‘submodel’?
Sim
Seed files are used for publishing the i-models. So if you want to publish an i-model you save the model as seed.
When you are exporting the model as submodel all the properties except the Element Symbology i.e. Color coding & the annotations get exported.
Sushma Choure
Bentley Technical Suppport
A seed file is like a template. You can save to a seed a file that you want to use as a base for all new projects. It has an .sts extension.
When you export to I-model, the software creates a .i.dgn file. When exporting to an I-model you had the options of what elements to export.
When you do a 'Save', it is saving to the normal file format of a .wtg and .wtg.mdb or .wtg.sqlite file.
Terry FosterTechnical SupportHydraulics and Hydrology product lineBentley Systems, Inc.
