I have a model I have been working on which contains a detention pond with multiple areas contributing flows into it. We are developing a site adjacent which has underground stormwater piping which outlets into the pond. In my model I have an outfall element linked to the pond using the boundary element boundary condition. This allows all backwater effects to be taken into account as pond levels exceed our outlet elevation. I also have 2 catchments which drain directly to the pond overland, so they are connected directly with the pond as an outflow element.
The problem I am having is that the outfall which is only supposed to carry flows from the underground piping is showing a much larger flow than the flow in the conduit. It doesn't make sense since there are no other elements connected to it. Does anyone know how I can fix this problem? I need to demonstrate our developments impact on the existing pond in order to utilize its capacity. I have attached a screenshot of the outfall, conduit, and their associated graph with flows.
Could you also provide the model so we can look into this? There are two options for sharing your model files on BE Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
communities.bentley.com/.../bentleysecurefilesupload.aspx
If you upload the model to Sharefile, please post here as well so that we know that it is available.
Scott Kampa
Bentley Technical Support
Scott,
I have uploaded the zip file with all of the model files to Sharefile and they are called Keller Site.
Ryan
Answer Verified By: RKJ
