Hi all I have imported through the loadbuilder my loads for the network. I have two questions:
1. Can I view on the plan map where these loads are, or do they not have x,y co-ordinates and only can be viewed on the maintenance holes that they are connected to.
2. Not all the loads were imported is there a distance adjustment that I need to do?
Cheers
Lee
Hello Lee,
The location of the loads should be viewable by applying the shapefile you used as a background file. The appearance of this will naturally be related to the appears of the shapefile, but you could get an idea of where they are located. The values being applied will not be displayed in the background.
To see the values applied, you can look at the Sanitary Load Control Center (found in the Tool pulldown menu) or annotate the nodes with the field "Flow (Local In)" which represents local inflow at a manhole that doesn't come from upstream links.
Reegards,
Scott Kampa
Bentley Technical Support
We will likely need some additional information on this issue. What method are you using to import the data? What format is the loading data in?
Scott
