Hello
There is a network which Demand Junctions based on Pattern. I want to select a VSP. Which Type of it must be selected? It seems that ‘Fixed Flow’ and ‘Pattern Based’ are not proper types here. The remained option is ‘Fixed Head’. But how can use it to force Pump to follow Pattern during an EPS. Sim
Mark
Mark Do you mean the situation which I described above (selecting a VSP for non-fixed demands junctions in downstream of a closed system) has not JUST ONE suggested solution and I have to test it with two types of VSP to consider which one is better? Did I comprehend correctly? Then what do you think about Jesse's idea? Sim
