Is it possible to SewerGems show the pipe crossing into the profile?
Hamid
Mark
Answer Verified By: Hamid.AKbari
Yes that was what I was looking for.
1-
I am going to show pipes crossing in the profile and label them as crossing from right/left , because the client CAD standard need it. Also, when you are dealing with a long profile and have some crossing in left/right , its better to see them and figure out why pipe in a specific node has drop because of pipe crossing or something
2-
I have another suggestion: is it possible to give access to user to set the "Slope calculated" as manually for each pipe in the next release? e.g. user select couple of pipes and set "user Slope calculated" manually to 3% and then software design cover and doesn't change slope anymore?
3- give access to user to either start design from upward or downward, because some designers prefer to start design from outfall!!
4-
Also, I know Bentley has a lot of software and good experts like you which could combine 2-3 software together and enhance software in market.e.g. Civil3D is a good software for providing profile and "3D object view" but they don't have any software for water/wastewater design! they have just SSA for the pipe analyse but Bentley does, but all of those are separated!
Another thing is ; it doesn't make sense for some (small) companies to buy a couple of software at the same time!
Believe me I like to continue my work by Bentley software, because I have been working with Bentley software for couple of years and it's a little bit hard to switch to a new software with new features, so please try to stay in market at top list, although in Canada " Hydraulic and Hydrology" packages is not active ( Specially in Greater Toronto Area) and clients just know Microstation and Inroad and sometimes WaterCAD,
Infoworks ICM is getting widespread and I think you should review/revise your marketing (or representative)!
