Dear All,
Under Case Folder: MODEL RUN_AL-REGGAH TO PS-P3, Case1 is without Al-Reggah Pump Station, while Case2 is with Al-Reggah Pump Station. My question is, why the output on PS-D1_581-C27, TPS_707-C01 & PS-D2_581-C27 is changing?. my understanding is that these should be fixed since the "Fixed level in Steady State" is set to "TRUE".
USING PRIORITY MODEL_P1+P3+P4.zip
June, I just looked at your model and I see that wet well PS-D1_581-C27 is staying at a hydraulic grade of -0.9 m in both scenarios. You can see this by running both scenarios and then either right clicking on the tank and looking at the data table or by looking at the properties of the tank for hydraulic grade. For TPS_707-C01 & PS-D2_581-C27 from what I see the property for "Is fixed level in steady state?" is set to false, so I would expect the calculated hydraulic grade to change unless you set the property to true. Regards, Mark
Mark
