Upon running a Modified Ration Method analysis, I am getting the Error Notification below and cannot figure out exactly what it means by the Allowable Flow and how it is computing this value, it does not correlate to any calculations I've done by hand. Any ideas on how to fix this?
Any help would be greatly appreciated.
Thomas Downer, P.E. HWR - Water Resource Consultants | Senior Hydraulic Engineer |
tdowner@hwr-plc.com
Sorry, the screen capture did not come out.
The Error Notification reads:
Message ID: -1
Scenario: Pre-Development 100 Yr.
Element Type: Catchment
Element ID: 31
Label: DA-1
Time (hours): N/A
Message: The flow (peak), 24.85 ft³/s, is less than the flow (allowable), 32.91 ft³/s.
Source: Engine Fatal Error
Tom
Thomas Downer, P.E. HWR - Water Resource Consultants | Senior Hydraulic Engineer | 804-310-6698
thomas.downer_hwr-plc@verizon.net
I'm looking at my alternatives and they are as usual. However, there are duplicated values in my Catchment Properties. I uploaded my model to this thread for you to take a look at, and below is a screenshot of what I am seeing:
