Hi
in the Scenario 1, pump A will discharge from link 1 but in scenario 2, pump A will discharge from link 2.
how can I indicate those in the SewerGems?
I already changed Active topology and physical alternative but still just get the one link and can't switch when I change the scenarios!
Hamid
Terry FosterTechnical SupportHydraulics and Hydrology product lineBentley Systems, Inc.
You can see the attached zip file.
I have 2 different scenarios :parallel vs separated.
I get an warning when compute the parallel scenario.
PUMP STATION.zip
Hello Hamid,
As the downstream link for the pump is not a part of the physical alternative, you will likely need to model another set up pumps with the correct downstream links. At issue here is that you cannot have two downstream links attached to a pump. In your model you have that. Instead, you will need to have a pump for each downstream link; the pump would be active when the downstream pipe is active and inactive when the pipe is inactive, similar to the screenshot below.
Scott
Answer Verified By: Hamid.AKbari
