Tank's out net doesn't work
Hi all. I have a problem with my network simulation. In my water distribution network, I have 1 Tank with 1 inlet and 3 outlets. The problem is why the water doesn't flow through the tank? In other word my outlet values always show negative and zero. Can anyone help me? Thanks before.
