Dear Team,
In my model (Day1 + water ADD), i set a pattern for my reservoir ie. it will be active for 16 hours then from for 8 hrs inactive. Initial age is set for '0'. The system is , reservoir supplies to tank for 16 hrs and stop supply but distribution from tank is 24 hrs. While performing age analysis, i am getting age for the pipe between reservoir and tank is 8 hrs. reservoir and tank is next to each other. ( Say pipe lenght is10m). so this 8 hrs is added upon the downstream pipes also from the tank. Hence, i am getting more age but it should not be the case. I need the water age at tank outlet should be Zero. Need your suggestions please. for sure water age in potable water network (Suffix with PW-) is less than 24 hours only. I model for your reference (Model) uploaded in secure file transfer.
Thanks for the consistent support.
With Regards,
RSP
RSP,
I see the results that you are talking about and they are displayed by the graph below:
The reason this is happening is because at 16 hours when you pattern stops flow from the reservoir there is no new supply of water entering the system, so the water in the pipe will age an hour at a time until the end of your 24 hour simulation. It sounds like you don't think the water should age in this pipe though, could you please explain why?
Mark
