Dear Team,
In my model, The nodes connected next to the pump in active topology has demand pattern( Grass lands) as 9-12 (3 hrs) and 18-21 (3 hrs) in a day. There are 7 pumps in (BP-16,18,19,23,25,26,39) feeding to grass lands demand.
As per the my understanding of the model, i should get warning msg for all the 7 pumps "Pump cannot deliver the flow or head" in each interval of time. Say at 0 hr 7 pumps warnings, at 1 hr again 7 pumps warning, same upto 8th hr. Since, as per demand pattern up to 9 hrs there is no demand. If no demand on the downstream side of the pump, then model has to give warning msg.
But looking at the users notification, it is not happening so!!!. At different hrs different pumps are giving warning msg but all the connected nodes are with same demand pattern. I suppose to get all 7 pumps warning at every hr. But, if i operate in steady state no error warnings at all.
Is it my understanding wrong? or how to do it?
Suggestions please. I attached the file for your use.
With Regards,
RSP.
