How to delete pipe in child scenario without deleted pipe in base scenario?
I have a full model which is then i want to split it into 2 area. I want to retain the full model as a base model and do a scenario for area 1 and 2 mean i created the child scenario with child alternative for each. Scenario for area1 will have only area 1 and area 2 will be deleted from full model in child scenario for area 1.
However, after i deleted the area in child scenario it also deleted the asset in base scenario.
Please advise what should i do?
Azizah
