Hello.
Is there any way to get 3D view of WaterCAD model with pressure in every node showed as 3D cylinder or column sized depending on pressure value?
It used to be in CyberNet water modelling software, but I can't find it in WaterCAD now.
Thank you!
Bentley has a feature called i-models. From WaterCAD, you can export to an i-model. With this file you can user the Bentley i-model Composer to view the file. Here is a support solution that explains some of the Bentley i-model Composer: http://communities.bentley.com/products/projectwise/project_review/w/wiki/7015
If you need further clarification, please let us know.
Terry FosterTechnical SupportHydraulics and Hydrology product lineBentley Systems, Inc.
