I have loaded up an xref file on AutoCAD however, when I begin to create a network using the stormCAD tools in AutoCAD, the snap function seems to disable each time I try to draw the conduit over the x-ref. Any advice?
You may want to check your snap settings. You can type snap at the command line and the drafting settings will pop up. Check the X/Y spacing as well as the snap type. Depending on what type of xref file you have, you may be able to import the file using ModelBuilder to create the model for you instead of tracing over the drawing. Please check out this support solution on creating a model using ModelBuilder: http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/2821
Terry FosterTechnical SupportHydraulics and Hydrology product lineBentley Systems, Inc.
