Is waterCad could prove the pipes size and tank filling from the top as described below?
The purpose is to size the pipe to be able to fill 500 cu.m in two hours (pipe length = 300m), the velocity in the proposed pipe 1 m/s.
how is the model could be? and is the model can show the filling time of the tank?
As mentioned by Jesse, you need to see graph of percent full, on the graph itself you will see the time on X-axis required to fill the tank.
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Jesse Dringoli
