I have modelled a sewage collection network and designed it in SewerGEMS V8i. I am getting different values for Depth (in), Depth (Middle) and Depth (Out) for the conduits. I expect them to be same, as there is no addition/ extraction of flow or, change in diameter, or, change in slope within any particular conduit.
Sample1.stsw.zip
Sushma Choure
Bentley Technical Suppport
The reason for different depth of water is gradually varying flow in the pipe. Flow is governed by continuity,momentum and energy principal.
Indranil Basu
