I am working in SewerGEMS 08.11. .
Model is computed in Explicit (SWMM solvers). The problem is very strange, because model is worked fine until i change sanitary loads, ever since then results are N/A. When I try to compute earlier version of model with unchanged sanitary loads also the results are N/A. I try to compact database and to separate stsw.sqlite files in new folder but that doesn`t help. But I try to run model in SWMM and all work fine and also I try compute model in Implicit solver and model are showing results.
Can you tell me what can cause this kind of problem and what can i do?
Matija
I have only one notification.
Under Calculation Summary i do not have any errors only warnings (02,04) . Earlier version of that model also do not show results ( before runs successfully for sure ).
Also when I export it to SWMM he compute successfully.
This is informational message. We would need a copy of your model to comment further. There are two options for sharing your model files on BE Communities. If you would like the files to be visible to other members, compress the files into a zip file and upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley. http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload If you send the model, please post here so we know it is available.
Sushma Choure
Bentley Technical Suppport
