Hi
as far as I understood, for the "invert in" label I should use "Elevation(invert1,2,3,....) and for "invert out" I can use "Elevation (invert)".
but I don't want to see invert in as (N/A) where there is not invert in available in the manhole!
is there any way to come up with that, because e.g. Civil3D show up the "invert in" just where they are available
Hamid
Hi Jesse
Thanks for your follow up
I am using GVF Convex and just created some labels in "Element Symbology"
I want to software automatically delete those "N/A" labels and shift the next label up!
E.g .in MH-10 delete N/A and shift "INV(out)" up in bottom of Ground.
Hello Hamid,
You can make a selection set a number of different ways, such as by going to View > Selection Set. You can also select all of the elements you want to include in the selection set, then right-click and select "Create Selection Set." You can find more information on Selection Sets in the Help documentation.
Once you have the selection set created, you can use it as a filter in Element Symbology. Edit your existing annotation to view the annotation properties. On the right side of the dialog is an item called "Selection Set." You can select the appropriate selection set for the annotation.
When you apply this, only the elements in the selection set will have the annotation. The others will note. Note that filtering by selection set also works for color coding.
Scott
