Topology-Connect to existing system
Hi
I am going to connect the new system ( white lines) to the existing system (red line).
Firstly, I have to analyse the existing system, Secondly, I should design the new system and finally , I should analyse whole system to see the existing system have enough capacity to capture the flow from the new system(white line).
I know how to do them one by one, but in term of analyse whole of system I have some questions:
what is the best approach for the topology of the system? I mean I have one topology for the Ex network and one topology for the new network how can I combine those as the third topology
Hamid
