Dear All,
We are experiencing difficulties on running the whole model. After few iterations, the model hang and never respond anymore, without generating any output report.
Attach is the SewerCad Model for your use/review.
Any help are will be highly appreciated!
Thank you very much in adavance!
June2015_May 19_Inquiry.zip
Hi June,
I was also working on this model and found some issues with a few of your pumps that I wanted to bring to your attention. He's what you should do to locate them. Go to View > Network Navigator from there make the following selections as shown in the screen shot below:
After you run that query on the system click the pencil like icon that you see highlighted below by the red box. This will select all the places there are loop in your system as seen by the cyan select of pipes to the right of the screen shot.
In some of the highlighted section pay attention to the directions that your pumps are facing. One pump is facing the wet well and the other pump is facing away from the wet well (opposite the first pump). I'm not sure if this is how the system was supposed to be laid out, but I figured I would bring it to your attention since it seemed different than your other pump/wet well setups. One example of this are the pumps at wet well PS-37_076-C06.
For more information on using network navigator please see this technote:
https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/3149
Mark
