I have a pump station that has 5 constant speed pumps (11,700 gpm each) I would like to install a valve that maintains a certain pressure in the system.
This valve shall remain close as long as the set pressure is maintained, once the pressure gets higher due to a lower demand in the system, it shall open to discharge to the atmosphere. As per the attached, I am thinking to install this valve on the header.
Would you please explain how to do so? and which valve I need to use? I tried using the Discharge to Atmosphere and PRV valves and they didn't work.
Answer Verified By: Pedro Mojica
