I'm working on a profile for wastewater, where the end point of the profile is below the initial quota. I was asked to scale a hydropneumatic type Dipping Tube, but due to the profile slope, soon after the stop of the pumps, the tank runs out of water and the hydraulic damping of the shock is not effective. What can I do in this situation to improve the protection of conduct? Changing the type of reservoir will not be solution because it also will be without water after some time. I'm trying to keep the size of the equipment as small as possible.
Repoir details:
"THE EXTREME PRESSURES AND VOLUMES OF THE GAS IN THE TANK AT NODE "HT-2" ARE AS FOLLOWS: MAXIMUM PRESSURE OF GAS = 5.23 MINIMUM PRESSURE OF GAS = -4.25 MAXIMUM VOLUME OF GAS = 25.4 MINIMUM VOLUME OF GAS = 1.0 *** WARNING: Maximum calculated gas volume (.25E+02m3 ) exceeds the volume of the hydropneumatic tank (.52E+01m3 ). A larger tank should be used at node HT-2."
Best regards
Ricardo
Jesse Dringoli
Thank you very much for your reply. However I have already tried everything that I remember, and I have no solution. Even a 20000 l tank is not a reliable solution, because due to the slope of the profile sooner or later it runs out of water. Increase the inertia of the pump does not work too. So I've been thinking if some change on the piping could help. It is not possible to use some type of valve in the end of the piping, in order to limit the pressure or push up the hydraulic grade? I already tried a PSV, but it does not solve my problem either. I put some air valves in the piping, which help a bit but is not enough (picture).
I hope you can help me, because I'm running out of ideas.
Thank you
Ricardo Silva
